UE虚幻资源 [模型/材质] Battle Royale Island Pack 大逃杀开放世界岛屿地图环境场景UE 虚幻游戏素材资源
504
6
引擎插件类型
软件版本要求: 版本:4.23及以上版本
引擎插件类型: 模型|贴图 材质|Shader 地图编辑
价格:100元素币(或10余额) 百度网盘 销售总额:0元素币 购买人数:0
尊敬的游客 ,本内容需要支付 100元素币十分之一的[余额] 来购买.
大小:11 GB,使用软件:UE 5.0-5.1,语言:英语。
两个开放世界的岛屿地图,有4x4km的16级流景,以及超过650个高质量的网格,适合各种类型的游戏制作。
Battle Royale Island Pack includes plenty of architectural elements & wide-range of props for you to explore and create custom-made environments. Create unique environments through the selection of carefully detailed work including elements of common country-life, suburban living, military props and generic set of natural elements.
We give our many thanks to Gökhan Karadayı for his help while creating this environment.
There are over 20+ settlements from small villages to larger towns, or fields and farms with various plant arrangements. Hiking routes, dense forest areas that play with the light, grasses covering the landscape reaching as far as the player can see.
The meshes include Barns, Silos, Village Houses, Fences, Windmill, Asphalt & Concrete Roads, Railroad Tracks & Props, and natural assets of several types of grasses, bushes, farm plants, common foliage & trees. There are 85 BP meshes including houses and settlements with applied physics to the doors for entering. Proxy meshes, trimsheet textures, LOD arrangements, cull distances are added to optimise the performance of this open world environment.
More Screenshots
Showcase Video
Features
How to load main level
Performance
Cull Distance Settings for performance
UPDATE : The orphan mesh error and the embedded road issue is solved. (All the road meshes are now landscape spline.)
Technical Details
Features:
2 Open World Islands (Maps a & b) with 16km2 landscape/ with landscape layer materials and auto-material
A level of display with structures, props and natural elements deployed: BattleRoyale_Map_a
Level Streaming features for large-sized landscapes
Realistic water blueprint with proper post-process adjustments
Adjustable materials with plenty of options to customize
Ready to deploy 85 Blueprint mesh prefabs for quick environment creation
High number & variety of meshes for building elements, props and natural settings
C-130 Hercules look-alike plane mesh with enterable back space
Number of Unique Meshes: 670
Collisions: Both custom-made & automatically generated
Vertex Count:
Min. 24 [SM_Beam_1]
Max. 165,299 [SM_Barn_5]
LODs: Yes, 3 LODs
Number of Materials and Material Instances:
41 Materials
271 Material Instances
20 Material Functions
Number of Textures: 865
Texture Resolutions: [1024x1024] to [4096x4096]
Supported Development Platforms:
Windows: Yes
Versions: 4.23 and up
大逃杀岛屿包包括大量的建筑元素和广泛的道具,供你探索和创建定制的环境。通过选择精心制作的作品创造独特的环境,包括常见的乡村生活、郊区生活、军事道具和通用的自然元素集。
这里有超过20个定居点,从小村庄到较大的城镇,或者有各种植物排列的田野和农场。徒步旅行的路线,密集的森林地区,在光线的作用下,覆盖在景观上的草可以达到玩家的视野。
网格包括谷仓、筒仓、村舍、栅栏、风车、沥青和混凝土道路、铁轨和道具,以及几种类型的草、灌木、农场植物、普通树叶和树木的自然资产。有85个BP网格,包括房屋和定居点,并对进入的门进行了物理学处理。为了优化这个开放世界环境的性能,添加了代理网格、修剪表纹理、LOD安排和剔除距离。
特点:
2个开放世界的岛屿(地图a和b)有16平方公里的景观/有景观层材料和自动材料。
一个有结构、道具和自然元素部署的展示层面。BattleRoyale_Map_a
大尺寸景观的水平流功能
逼真的水景蓝图,具有适当的后处理调整功能
可调整的材料,有大量的选项可以定制
随时可以部署的85个蓝图网格预制件,用于快速创建环境
用于建筑元素、道具和自然环境的大量和多样的网格
C-130 "大力神 "飞机网格,可进入背部空间。
独特网格的数量:670
碰撞:自定义和自动生成的都有
顶点数量。
最少24个[SM_Beam_1]。
最大:165,299 [SM_Barn_5] 。
LODs:是的,3个LODs
材料和材料实例的数量。
41种材料
271个材料实例
20个材料功能
纹理的数量:865
纹理的分辨率:[1024x1024]到[4096x4096]。
支持的开发平台:
Windows:是
版本:4.23及以上版本
参与人数 3 元素币 +33 活跃度 +18
哔咔哔咔  发表于 2022-12-31 09:43:21
666666666666666666666666666666666
书叹  发表于 2023-1-1 14:14:24
超级棒了!~!
狂奔de蜗牛  发表于 2023-1-2 20:29:11
黄海  发表于 2023-1-3 10:25:53
大家来给我点个赞
曼珠沙华 实名
21 小时
幻焱之玉 白晶石 双杀 蓝月药水 粉晶石 长枪 蓝色史莱姆 长剑
