Unity3D资源 [功能/工具] [unity插件]UNOShader Unlit w/Toon 超牛材质插件-最新1.5版本(百度网盘)
190
引擎插件类型
软件版本要求: 要求Unity 5.1.0或更高版本
引擎插件类型: 材质|Shader 后处理
价格:999元素币(或99余额) 百度网盘 销售总额:999元素币 购买人数:1
尊敬的游客 ,本内容需要支付 999元素币十分之一的[余额] 来购买.
资源包名: UNOShader Unlit w/Toon 着色器发布者:UNOverse Entertainment价格:$35适用版本:要求Unity 5.1.0或更高版本。文件大小:17.61MB资源有问题.或者链接不存在.请私信.或者Q群小窗.看到立马解决
Asset store 链接:https://www.assetstore.unity3d.com/en/#!/content/19440
Requires Unity 5.1.0 or higher.This is a material editor extension that creates and toggles between shaders on the fly.It uses Shader Model 2.0 as a base, so it is faster then a surface shader and great for Mobile!!Features:Property toggler: Color / Diffuse / Decal / Decal tint Reflection / Rim / Emission / Outline Xray / Texture Masks Lighting / Shadows - Toggle Ambient / Directional light Process - Toggle Shadow Process - Custom shadow color BRDF Texture lookup - Use a texture ramp to control light fall off and Rim effect Reflection - HDR support / Metallic Support - Respects probe reflections (note. Does not blend when transitioning from one to another) Rim - Fresnel support - Emission(Intensity) Emission - Independent baking intensity vs viewport display intensity Outlines - Works on 2d Camera - Control X/Y width of outline - Use texture to color outline Xray - See silhouette behind objects - Control color/transparency Lightmaps - Use unity\'s lightmap or provide your own on UV1 or UV2 Other - Vertex Colors support - Opacity sliders for almost every property - Transparency slider and Edge opacity (new) - Built in UV scroller so you don\'t have to keep attaching scripts to your objects - Built in render queue sorting order for transparent objects - There is no need to offset stacked geometry. Blend as many textured geometry layers as you want. And many others not listed...
成林 实名
unity3D
5805 小时
【绝】结界玄晶 微库VIP 扩散者 紫色药水 学徒法袍 元素铜币 元素银币 元素金币 元素秘币 长剑 绿色药水 长枪 火元素
