UE虚幻资源 [模型/材质] 手绘风格头发着色材质实例虚幻4UE4 Stylised Hair Shader
839
2
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 材质|Shader
价格:50元素币(或5余额) 百度网盘 销售总额:100元素币 购买人数:2
This pack features an alternate shader method for producing hair. It avoids using intense math or light calculations so could be considered as fake but convincing hair which handles transparency and anisotropy in the nicest possible way.
Nine example materials have been created from the master shader material.
Supplied with a base RGB, Opacity and Normal Map of hair strands, along with a base hair wig with more to follow in future updates. These Hair stands were generated with Hair Strand Designer which generates the RGB mask maps used in this shader. If you want to drive your own custom colouring, simply paint the base various tones of Red, then paint the roots Green and the Tips Blue, this opens up the possibility of customising in the engine or even in your game.
A Secondary shader has been setup to work with pre-existing colour textures. It also supports Frizz, AO and Depth images which also work in this alternative shader. Hair Strand Designer is sold separately and is a great way to produce all of the hair textures you will need.
Parameters include: Fresnel , Dual Base colouring, Root and Tip Colouring, Normal Map bending, Shine, Specular,Frizz and Opacity control. Newly added - Rainbow or Oily effect that can be used as a base mix or even emissive.
Videos:
-- DEMO VIDEO --
-- RAINBOW EFFECT (UPDATE) --
Check out the above example videos for for details on how to use this shader.
技术细节
Features:
Uses RGB to drive Variation, Root and Tip Colours respectively.
Comes with a full array of parameters for the ideal overall look and feel
Will work as a realistic and stylised hair shader
Uses a new rainbow effect for the oily look, purely for style
Texture Resolutions:
Hair Strand Textures are 4096 * 4096
Frizz map is 2048*2048 with the ability to be tiled via the parameters.
Number of Materials: 9
Do Materials derive from a Master Material with instances as variation: Yes
Number of Textures: 4
Supported Development Platforms: PC
Supported Target Build Platforms: PC
参与人数 3 元素币 +36 活跃度 +25
长生但酒狂  发表于 2022-7-28 19:54:49
提取码呢?
书臣  发表于 2022-12-29 18:51:17
超级棒呀。大神你的作品真的很棒呀。
我嘞--个豆 实名
20 小时
元素之钻 英雄盾 钢盾 双杀 水晶剑 元素金币 长枪 青色史莱姆 长剑
