1 Modular Substance Material, set up for Tessellation, for use with the Landscape Spline Tool.
29 Material presets generated from that 1 substance Material.
2 basic subdivided spline mesh parts included that you can use with the Materials for the Landscape Spine Tool, or make your own.
Pack comes with a sourcefiles folder containing the substance designer files so if you have substance designer installed you can load up the Material and modify it however you want. Visible through file explorer.
Example vids: https://youtu.be/tjmnJHosE4M https://youtu.be/q3PK2GsxTl0
Simple Tutorial Vid: https://youtu.be/pWm_aOfN6rk
技术细节
Documentation: (https://drive.google.com/open?id ... mrLotDtOjcmJDbvGGHK)
REQUIRES THE SUBSTANCE PLUGIN https://www.unrealengine.com/marketplace/substance-plugin
1. Create a blank project (should work with your current project to but starting with a blank project makes sure nothing else is causing problems with it), enable the substance plugin and restart.
2. On restart, go to Edit > Project settings, scroll down to and click on Substance under plugins section.
3. In the substance plugin settings, under the “cooking” tab, switch it from cpu engine to gpu engine.
4. Now exit out of the empty project and install the Substance Material Pack to the empty project, and reopen the project
5. Click on the example map to load up and you should see it compiling the shaders and then everything should be there.
Features:
1 Substance Material
29 Material presets
Built in tessellation support
Texture Resolutions:
145 Textures at 2k resolution
Number of Materials: 1 Master Material, 29 Material presets
Do Materials derive from a Master Material with instances as variation: (Yes)
Number of Textures: 145
Supported Development Platforms: (Windows, MAC)
Supported Target Build Platforms: (Windows, MAC)
