UE虚幻资源 [模型/材质] 园林花园园艺场景虚幻4ue4 Flowersand PlantsNature Pack
222
4
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 模型|贴图
价格:50元素币(或5余额) 百度网盘 销售总额:50元素币 购买人数:1
https://www.unrealengine.com/marketplace/en-US/product/flowers-and-plants-nature-pack
HighresScreenshot00017-1920x1080-0164a80c112d5c79a6865569dfbc7d1a.jpg HighresScreenshot00018-1920x1080-4eee6dd43adca681a6257b8b4068625a.jpg
Includes more than 140 plant species.
760 HQ Static Meshes:
648 flowers and plants;
28 vegetable spline elements;
84 environment models.
This pack will allow you to create beautiful natural scenes. The advantages of this content are flexible settings of wind and material, interaction with the character, high optimization.
The master plant material allows you to customize a variety of wind parameters: Waves, Swaying, Simple Grass Wind, Shadow Waves and much more.
There is a system of interaction between plants and the character.
The material is structured and contains comments. Description of all parameters in two languages (eng and rus)!
There is a master instance that allows you to change the parameters of plants globally.
High optimization: each model contains 2 LODs, including billboards for some complex models.
Blueprint "BP_Settings", which allows you to globally adjust the wind (speed and direction)
***Monthly Unreal Engine Sponsored Content product for October 2019***
Check out Dragon Motion's other products here: https://www.unrealengine.com/mar ... ofile/Dragon+Motion
NOTE: If the scene is lighter or darker, change the auto-exposure parameters in post-processing.
Warning: The landscape or water material included in the content may not be displayed when the "Forward Shading Renderer" is enabled, depending on the versions of the UE4 engine. This is due to some limitations of the render. If you have problems with displaying materials, disable "Forward Shading Renderer" in the project settings.
Technical Details
Physically-Based Rendering: Yes
Texture Size: from 512*512 - 4096*4096
Collision: Yes, custom
Triangle Count: on average 1092 per 0LOD, 314 per 1LOD, 91 per 2LOD
LODs: Yes, 2 LODs for each model + billboards for some
Number of Models: 760
Number of Blueprints: 13
Number of Material Instances: 579
Number of Master Material: 6
Number of Textures: 2208 (includes Albedo, Normal map, Metallic+Roughness, AO)
Platforms Tested: Windows 10 x64
Tested Platforms and configurations:
PC 1
CPU: i7-3770 3.8 GHz
GPU: Gtx 1060 6Gb
RAM: DDR3 16Gb 1333Mhz
OC: Windows 10 x64
PC 2
CPU: i7-7700K 4.2 GHz
GPU: Gtx 1080ti 11Gb
RAM: DDR4 32Gb 3333Mhz
OC: Windows 10 x64
Demo Scene (Epic Quality) Unlocked fps
PC1: 70-130 FPS Average fps: 80-95
PC2: 100-250 FPS Average fps: 125-130
Demo Scene (Medium Quality) Unlocked fps
PC1:  100-160 FPS Average fps: 105-120
PC2:  120-300 FPS Average fps: 180-190
>Our works<
>ArtStation<
会者定离,一期一祈
半边翅膀  发表于 2022-7-8 14:26:30
资源缺少 关卡无法打开
ゞ囙艏往倳ゞ  发表于 2022-11-18 10:57:43
感谢分享 ~!
little219  发表于 2023-5-19 17:24:30
4.27版本的关卡确实打不开,,里边材质球报错,,,认不到材质,,,
qq_欣欣_wUj  发表于 2023-5-31 08:38:02
搞点活跃度,每日一登录
无言的侵袭 实名
风花雪月
17 小时
长剑 火元素
