UE虚幻资源 [模型/材质] 高级主材质水虚幻4UE4 Customizable Water Master Material
452
3
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 材质|Shader
价格:50元素币(或5余额) 百度网盘 销售总额:150元素币 购买人数:3
https://www.unrealengine.com/marketplace/zh-CN/product/customizable-water-master-material-vertex-paintable
FEB 2021 UE4 SHOWCASE PICK
Click to Watch the Teaser
Important: In my new update there is a switch under foam properties called \" foam 1 or 2?\" Use that to choose the foam look you want. Each of them has pros and cons. Foam 1 is nicer but it might get stretched however foam 2 doesn\'t get stretching artifact at all.
Important: Foliage such as grass, mushroom and textures such as leaves and Lilly-pad are from
Megascans. They are just there for demonstration purpose and they are not included inside the package.(Moss texture is included)
If you are eligible to use Megascans Assets you can download the vertex-paint textures from the preview here:
Vertex-paint Textures:
Leaves texture
Dollarweed Leaves
Assets and foliages:
Red mushroom
Ribbon grass
Mossy stones pack
Top police car
Crate
Wood boards
技术细节
How to use:
Click to Watch Tutorial
Features
1) Refraction with adjustable intensity, opacity, etc. (on/off switch)
2) Raindrop ripples effect on the surface. (on/off switch)
3) 2 vertex-paint channels enabling you to paint Moss, Leaves, lily pads, or anything you want on the surface of the water. (on/off switch for each channel)
4) Adjustable tile size for each vertex paint material. Adjustable speed and intensity for the movement.
5) Replaceable normal map for waves patterns enabling you to choose your tileable normal map.
6) Adjustable size, intensity, and speed for wave normal map.
7) Dynamic foam and ripples around the intersecting objects and shoreline. Adjustable spread radius, speed, opacity, and color for the foam. (on/off switch)
8) Adjustable depth parameter.
9) Adjustable colors for shallow and deep areas with contrast control between them.
10) World displacement Gerstner waves. (on/off switch)
11) 2 Gerstner wave variation with adjustable size, speed, height, and wavelength for each set and one overall intensity controller.
12) Tessellation multiplier.
13) The material is tiled all over the world allowing you to resize your water plane without any change in the size of waves or patterns. Also enabling you to snap each piece of the plane together without any seam line.
参与人数 1 元素币 +1 活跃度 +1
b877168688  发表于 2023-7-1 18:53:17
zwzwzwz  发表于 2023-7-2 21:39:55
啱买完菜翻来  发表于 2024-5-23 11:30:22
DJ_2013 实名
18 小时
长枪 蓝色史莱姆 长剑 光之杖
