Unity3D资源 [功能/工具] [unity插件] Amplify Color 1.6.3(最新) - 碉堡专业级的调色插件!强力推荐!(百...
292
引擎插件类型
软件版本要求: 未知或无明确软件版本限制
引擎插件类型: 材质|Shader
价格:200元素币(或20余额) 百度网盘 销售总额:800元素币 购买人数:4
尊敬的游客 ,本内容需要支付 200元素币十分之一的[余额] 来购买.
资源包名:Amplify Color -1.6.3 - 碉堡专业级的调色插件(元素首发)-官方最新着色器/全屏幕及相机效果发布者:Amplify Creations价格:$25适用版本:要求Unity 3.5.7或更高版本。 (最新版本支持5.4,支持手机。楼主使用5.4测试没问题)文件大小:1.08MB资源有问题.或者链接不存在.请私信.看到立马解决Asset store 链接:https://www.assetstore.unity3d.com/en/#!/content/1894
NEW! Single Pass Stereo in Unity 5.4
Amplify Color is the lightest, most flexible,
Unity Extension for Industry Level Color Grading. Easy to use and to integrate into your project, no coding required and works well for both 3D and 2D games.
Click Here to see it in action
or Try Before You Buy
Looking for a cinema-grade LUT library? Check out the Amplify LUT PackDefine and blend Lut\'s (color profiles) between different areas, smooth and 100% Artist Friendly. Volumes may be scaled, moved, rotated and even animated. A flexible tool that will allow you to create stunning environments in no time.
The plugin can connect directly to Photoshop, or can also be used manually with similar tools like After Effects, Nuke and others. Use the software already in your pipeline to push color transformations directly into your Unity Project Scenes.
Supports All Platforms
Optimized for Mobile
Using your favorite editor you may alter the contrast, color curves, exposure, saturation, hue and more, or a combination of all transforms at once.
Not only will you be able to switch or blend between color profiles, you can even use a static Texture or a dynamic Render Texture as a mask to exclude certain areas.
• Industry level color grading
• High-performance and Mobile-ready
• Semi-automated Photoshop Workflow
• File-based mode for other Image Editors
• Dynamic blending between profiles
• Texture-based per-pixel masking
• All Color Alterations Supported
• Oculus/VR friendly
• Color Volumes
• Third-party Effects Volume Blending
• Base and Volume LUT mixing
• Complete source-code
• NEW! 2D Color Volumes
• NEW! Depth-based Masking
• NEW! HDR Tone Mapping
• NEW! HDR Dithering
• NEW! Broader mobile device support
• NEW! Improved tools
Take the WebPlayer Demo for a spin
Learn More at the Official Forum Thread
Make the change, use the professional tools you crave. Our products are developed by industry professionals and our support team always goes one step beyond to resolve any possible issues our clients might have.
Get in touch, we would love to hear your story, help promote and feature your work.
-----------------------------------------------------------------------------蹩脚软件翻译------------------------------------------------------------------------新!5.4单通道立体团结
放大颜色是最轻,最灵活的,
统一颜色分级扩展工业水平。
易于使用和集成到您的项目,不需要编码,适用于3 d和2 d游戏。
点击这里看它的实际应用
或者先试后买
寻找一个cinema-grade附近地区图书馆吗?查看放大附近地区
定义和混合附近地区的不同区域之间的(颜色配置文件),
光滑和100%的艺术家友好。卷可能扩大,移动,
旋转甚至动画。一个灵活的工具,它将允许您创造惊人的环境。
插件可以直接连接到Photoshop,或者也可以使用手动使用类似工具像效果后,
核和其他人。使用该软件已经在你的管道直接将颜色转换成统一项目场景。
支持所有平台
优化的移动
使用您喜欢的编辑器你可以改变的对比,色彩曲线,曝光,饱和度,色调,或所有转换的结合。
不仅你能开关或混合颜色配置文件之间,您甚至可以使用一个静态纹理或动态渲染纹理排除某些地区的一个面具。
•行业水平颜色分级
•高性能和mozilla移动
•半自动Photoshop工作流
•为其他图像编辑器文件的模式
•动态概要文件之间的混合
•Texture-based阴影掩蔽
•所有颜色变化的支持
•眼睛/ VR友好
•颜色数量
•第三方影响体积混合
•基础和附近地区混合体积
•完整源代码
•新!二维彩色卷
•新!地屏蔽
•新!HDR色调映射
•新!HDR犹豫不决
---------------------------实例导入截图:
官方截图:
爱上一只猫 实名
377 小时
六维几何 长枪
